Clone or erase 2.5in/3.5in SATA hard drives, without a host computer connection. The SATDUP11 standalone hard drive duplicator eraser enables you to copy 1-to-1 hard drive without a host computer.
Featuring three modes of standalone drive duplication including Data Only, All Partitions, and Sector by Sector, the HDD copier offers high performance duplication, and has been tested for speeds up to 14GB per minute.
Complete with integrated LCD display, and support for 2.5" and 3.5" SATA I/II/III hard drives (HDD) and Solid State Drives (SSD), the SATDUP11 is a user-friendly all-in-one solution for any application requiring hard drive duplication or erasing.
The SATDUP11 features high quality aluminum construction.
Product Description | StarTech.com 1:1 Hard Drive Duplicator and Eraser for 2.5" & 3.5" SATA HDD SSD - LCD & RS-232 - 14GBpm Duplication Speed - Cloner & Wiper (SATDUP11) - hard drive duplicator | Device Type | Hard drive duplicator | Colour | Black | Installed Devices / Modules Qty | 0 (installed) / 2 (max) | Supported Drives | SATA-600 | Localisation | North America, United Kingdom, Europe | Built-in Devices | Status LCD | Storage Controller | SATA (SATA 6Gb/s) | Power | AC 120/230 V - 50/60 Hz | Dimensions (WxDxH) | 7.7 cm x 11.5 cm x 2.5 cm | Weight | 500 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA12M5NA |
General | |
Enclosure Colour | Black |
Chassis | |
Installed Devices / Modules Qty | 0 |
Supported Devices / Modules Qty | 2 |
Storage Controller | |
Type | SATA |
Interface Type | SATA 6Gb/s |
Max Storage Devices Qty | 2 |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 2 (free) x external - 2.5" / 3.5" shared |
Interfaces | 2 x SATA 6Gb/s - 22 pin Serial ATA |
Miscellaneous | |
Cables Included | 2 x Serial ATA cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V - 50/60 Hz |
Dimensions & Weight | |
Width | 7.7 cm |
Depth | 11.5 cm |
Height | 2.5 cm |
Weight | 500 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 20 - 80% |
Compatibility Information | |
