This Cat 6 RJ45 Modular Plug can be used with Cat 6 bulk cables, allowing you to easily terminate your Cat 6 cable to the exact length equired.
Product Description | StarTech.com Cat 6 RJ45 Modular Plug for Solid Wire - 50 Pack (CRJ45C6SOL50) - network connector - clear | Type | Network connector - CAT 6 | Packaged Quantity | 50 (specifications are for single item) | Connector | RJ-45 - male | Colour | Clear | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: WIRC6CMPBLU |
General | |
Network Cable Type | Network connector - CAT 6 |
Colour | Clear |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
