Connect any SATA device to your development board, to increase its data storage capacity and performance. Increase the data storage capacity of your Raspberry Pi or other development board, by connecting it directly to a SATA-based drive. Perfect for custom projects and applications, this USB to SATA converter supports all models of Raspberry Pi as well as other development boards.
This convenient USB 2.0 SATA converter lets you overcome data storage limitations by enabling you to connect a SATA drive or SATA optical drive through your board's USB-A port. This enables you to access a wide variety of storage formats including solid-state drives or hard drives, DVD-ROM drives or CD-ROM drives.
The USB to SATA converter integrates seamlessly with your existing development board. It's the perfect addition for development-board based applications such as surveillance, media players and servers, digital signage and IoT/automation solutions.
Compatible with SATA I, SATA II and SATA III drives, the converter is easy to install, and doesn't require any device driver installation. It comes with a USB cable and all mounting accessories, including standoffs, so integrating it with your Raspberry Pi is fast and easy.
Product Description | StarTech.com USB to SATA Converter for Raspberry Pi and Development Boards - USB to SATA Adapter for Raspberry Pi Board (PIB2S31) - storage controller - SATA 6Gb/s - USB 2.0 | Device Type | Storage controller - internal | Bus Type | USB 2.0 | Colour | Red | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Hard drive, CD drive, DVD drive, solid state drive | Channel Qty | 1 | Dimensions (WxDxH) | 2.3 cm x 6.6 cm x 1.1 cm | Weight | 23 g | Manufacturer Warranty | 2-year warranty |
General | |
Host Bus | USB 2.0 |
Colour | Red |
Storage Controller | |
Channel Qty | 1 |
Processor | Renesas µPD720231A |
Expansion / Connectivity | |
Interfaces | 1 x SATA 6Gb/s - SATA |
Connections | 1 x USB 2.0 - mini-USB Type B |
Miscellaneous | |
Cables Included | 1 x micro-USB cable |
Features | USB powered |
Mounting Kit | Included |
MTBF | 6,481,043 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 2.3 cm |
Depth | 6.6 cm |
Height | 1.1 cm |
Weight | 23 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 15 - 90% |
