Add Bluetooth 2.0 with EDR capabilities to a computer, through USB. The USBBT1EDR2 USB to Class 1 Bluetooth Adapter with EDR is a micro-sized adapter that adds Bluetooth capabilities to a computer through an available USB port. This makes it possible to connect to devices wirelessly, at ranges up to 100m (328ft), with minimal power consumption. The USB-Bluetooth Adapter supports the Bluetooth v2.1 specification, along with Enhanced Data Rate (EDR), for transfer rates up to 3 Mbps. The adapter uses a small form factor design that makes it conveniently portable and unobtrusive, when connected to a computer.
Product Description | StarTech.com Bluetooth Adapter - Mini USB Adapter - Bluetooth 2.1 - Class 1 EDR - Bluetooth Receiver (USBBT1EDR2) - network adapter - USB | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | USB | Dimensions (WxDxH) | 1 cm x 2 cm x 0.6 cm | Weight | 2 g | Data Link Protocol | Bluetooth 2.1 EDR | Bluetooth Class | Class 1 | Data Transfer Rate | 3 Mbps | Frequency Band | 2.4 GHz | Compliant Standards | Bluetooth 2.1 | Colour | Black | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wireless |
Line Coding Format | DQPSK, GFSK, 8 DPSK |
Max Range Open Space | 100 m |
Status Indicators | Power, standby |
Features | USB powered |
Aerial | |
Antenna | Internal |
Expansion / Connectivity | |
Connections | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Colour | Black |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10 |
Dimensions & Weight | |
Width | 1 cm |
Depth | 2 cm |
Height | 0.6 cm |
Weight | 2 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 50 °C |
