Connect an HDMI equipped Laptop, Ultrabook, or Desktop Computer to your VGA Display, or Projector. The HD2VGAE HDMI to VGA Adapter/Converter actively converts an HDMI video source from your laptop, ultrabook, or Desktop computer onto a VGA HD15 projector or display.
With no need for an external power source, and support for resolutions up to 1080p (1920x1080), this active HDMI to VGA HD15 adapter offers a compact and portable solution.
Product Description | StarTech.com 1080p 60Hz HDMI to VGA High Speed Display Adapter - Active HDMI to VGA (Male to Female) Video Converter for Laptop/PC/Monitor (HD2VGAE2) - video converter - black | Device Type | Video converter | Max Resolution | 1920 x 1200 | Interfaces | 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) | Dimensions (WxDxH) | 4 cm x 24.5 cm x 1.5 cm | Enclosure Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Max Resolution | 1920 x 1200 at 60 Hz |
Interfaces | 1 x HDMI input - 19 pin HDMI Type A - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Width | 4 cm |
Depth | 24.5 cm |
Height | 1.5 cm |
Weight | 39 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 40 - 85% (non-condensing) |
