Need help finding a Laptop? Use our simple product finder to find a perfect match.
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080
Key features
  • High quality, compact design for long term durability and a minimal footprint
  • The adapter features a simple, plug-and-play design ensures a quick and easy setup
  • The HDMI to VGA adapter doesn't require an external power adapter ensures maximum portability
Product codes
chevron icon
chevron icon
Connect an HDMI equipped Laptop, Ultrabook, or Desktop Computer to your VGA Display, or Projector. The HD2VGAE HDMI to VGA Adapter/Converter actively converts an HDMI video source from your laptop, ultrabook, or Desktop computer onto a VGA HD15 projector or display.
With no need for an external power source, and support for resolutions up to 1080p (1920x1080), this active HDMI to VGA HD15 adapter offers a compact and portable solution.
chevron icon
Product Description StarTech.com 1080p 60Hz HDMI to VGA High Speed Display Adapter - Active HDMI to VGA (Male to Female) Video Converter for Laptop/PC/Monitor (HD2VGAE2) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Dimensions (WxDxH) 4 cm x 24.5 cm x 1.5 cm
Enclosure Colour Black
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
