The DVIVGAMF DVI-I to VGA Display Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
Product Description | StarTech.com DVI to VGA Cable Adapter - DVI (M) to VGA (F) - 1 Pack - Male DVI to Female VGA (DVIVGAMF) - VGA adapter | Type | VGA adapter | Connector | DVI-I - male | Connector (Second End) | HD-15 (VGA) - female | Colour | Beige | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: MXT101MMHD15, MXT101MMHD6 |
General | |
Colour | Beige |
Connectivity | |
Connector | 24+5 pin combined DVI - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
