One high performance storage solution to support two SSD or HDD drives. This USB 3.0 2-bay enclosure for 2.5in drives gives you the performance you want in an external storage system - and features a stylish, compact design that looks great next to your Mac or PC. Ideal for professional business settings or home offices, it provides a powerful data storage solution for your desktop computer, laptop, Ultrabook or Chromebook.
The dual drive enclosure lets you install two 2.5in SSDs or HDDs (from 5mm to 15mm) to create high capacity external data storage. To maximize the performance and speed of your SATA III (6Gbps) drives, the enclosure is enhanced with UASP delivering up to 70% faster transfer speeds than conventional USB 3.0.
The compact design, small footprint and sleek finish make this enclosure the perfect desktop companion for your Mac or PC.
Requiring only 5V of power, you have the option to power the enclosure through USB alone, without the need for an external power adapter. It can be powered through a single or two USB sources, such as USB chargers or ports on your laptop, depending on your drive set-up. In stationary applications or configurations where more power is desired, a power adapter is included. The enclosure gives you a convenient, energy-efficient storage solution with flexible storage set-up options - and easy portability.
Enjoy peace of mind, knowing your files are continually backed up or take advantage of greater speed and capacity offered with a combined solution. The enclosure supports RAID 0, 1, Spanning, and JBOD, enabling you to choose your preferred backup mode. With the convenience of RAID, you can achieve increased size, performance, or redundancy.
The enclosure is compatible with Windows, Mac, and Linux systems without having to install additional drivers or software.
This high-performance SuperSpeed USB 3.0 enclosure supports data transfer rates of up to 5Gbps and is enhanced with UASP support, which can deliver ~70% faster read speed and 40% faster write speed over traditional USB 3.0, when paired with a UASP-enabled host.
UASP (USB Attached SCSI Protocol) is supported in Windows 8, 8.1, Server 2012 and Linux kernel 2.6.37 or later. Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
The S252BU33R dual-bay enclosure is ruggedly built to deliver long-lasting performance.
Product Description | StarTech.com Dual Bay 2.5in Hard Drive Enclosure - USB 3.0 to SATA III 6Gbps with RAID - hard drive array | Device Type | Hard drive array | Colour | Black | Max Supported Capacity | 4 TB | Interface | USB 3.0 | Installed Devices / Modules Qty | 0 (installed) / 2 (max) | Supported Drives | SATA-600 | Storage Controller | RAID (SATA 6Gb/s) - RAID RAID 0, 1, JBOD, BIG | Power | AC 100/230 V | Dimensions (WxDxH) | 5 cm x 13.2 cm x 9 cm | Weight | 350 g | Designed For | P/N: DKWG30DPHPD, DKWG30DPHPDU, HB30A3A1CSFS, SVA5H2NEUA, USB3DDOCKFT |
General | |
Enclosure Colour | Black |
Chassis | |
Installed Devices / Modules Qty | 0 |
Supported Devices / Modules Qty | 2 |
Storage | |
HDD Array External Interface | USB 3.0 |
Storage Controller | |
Type | RAID (USB 3.0) |
Channel Qty | 2 |
Interface Type | SATA 6Gb/s |
Max Storage Devices Qty | 2 |
RAID Level | RAID 0, RAID 1, JBOD, BIG |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 2 (free) x internal - 2.5" |
Interfaces | 1 x USB 3.0 - 9 pin USB Type A , 2 x SATA 6Gb/s - 22 pin Serial ATA |
Miscellaneous | |
Features | Built-in cooling fan |
Cables Included | 1 x USB 3.0 cable , 1 x USB power cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 100/230 V |
Dimensions & Weight | |
Width | 5 cm |
Depth | 13.2 cm |
Height | 9 cm |
Weight | 350 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
