We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Connect a DisplayPort-enabled desktop to 4K 60Hz High Dynamic Range (HDR)-capable HDMI monitor, using this 6.6-foot (2-meter) Active DisplayPort to HDMI Adapter Cable.
Product Description | StarTech.com 6.6ft (2m) DisplayPort to HDMI Adapter Cable, 4K 60Hz with HDR, DP to HDMI 2.0b, Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (6F-DP-HDMI-4K60-HDR) - adapter cable - DisplayPort / HDMI - 2 m | Cable | Adapter cable - DisplayPort / HDMI | Length | 2 m | Colour | Black | Connector | DisplayPort - male | Connector (Second End) | HDMI - male | Compliant Standards | DisplayPort 1.4 | Features | 4K60Hz support, HDR support | Manufacturer Warranty | 3-year warranty |
General | |
Cable Type | Adapter cable 4K60Hz support, HDR support |
Interface Supported | DisplayPort / HDMI |
Jacket Material | PVC |
Length | 2 m |
Plated Connector | Gold |
Features | HBR3 audio support, HDCP compliant, active cable (signal regeneration), bus powered, outer diameter 5mm, bandwidth of 18 Gbps, EMI protection, 7.1 audio channel support (HDMI), wide screen support |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight | |
Weight | 82 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 17 cm |
Shipping Depth | 20 cm |
Shipping Height | 1 cm |
Shipping Weight | 85 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
