Convert a DB9 male port to a DB25 female port. The AT925FF DB9F to DB25F cable adapter converts a 9-pin serial port into a 25-pin female port.
Product Description | StarTech.com DB9 to DB25 Serial Cable Adapter - F/F - Serial adapter - DB-9 (F) to DB-25 (F) - AT925FF - serial adapter - DB-9 to DB-25 | Type | Serial adapter | Connector | 9 pin D-Sub (DB-9) - female | Connector (Second End) | 25 pin D-Sub (DB-25) - female | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: EC1S232U2, ICUSB2321FIS, ICUSB2322F, ICUSB2322I, ICUSB2328I, ICUSB232DB25, ICUSB232FTN, ICUSB232INT1, ICUSB232INT2, ICUSB232IS, ICUSB232PROC, PCI2S1P2, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S952LP, PEX4S553, PEX4S553B, STCPEX2S553 |
General | |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: 10PKPCI1S550, EC1S232U2, IC485S, ICUSB232, ICUSB2321FIS, ICUSB2321X, ICUSB2322F, ICUSB2322I, ICUSB2322X, ICUSB2324X, ICUSB2328I, ICUSB232DB25, ICUSB232FTN, ICUSB232INT1, ICUSB232INT2, ICUSB232IS, ICUSB232PROC, PCI1S550, PCI2S1P, PCI2S1P2, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S952, PEX2S952LP, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP, PEX8S952, STCPEX2S553 |
