We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Route this Ultra High Speed HDMI 2.1 Hybrid Active Optical Cable (AOC) through office plenum spaces for long distance transmission of 8K 60Hz video and high quality audio.
Product Description | StarTech.com 30ft (9.1m) HDMI 2.1 Hybrid Active Optical Cable (AOC), CMP, Plenum Rated, Ultra High Speed HDMI Fiber Optic Cable, 48Gbps, 8K 60Hz/4K 120Hz, HDR10+/FRL/TMDS/eARC - CMP In Wall HDMI 2.1/2.0 Cord (8K-A-30F-HDMI-CABLE) - HDMI cable - 9.1 m | Cable | Ultra High Speed - HDMI cable | Technology | Hybrid copper/fibre optic | American Wire Gauge (AWG) | 28/30 | Length | 9.1 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Features | Active Optical Cable (AOC), 4K120Hz support, 8K60Hz support, 4K60Hz support | Manufacturer Warranty | 2-year warranty |
General | |
Cable Type | Ultra High Speed - HDMI cable Active Optical Cable (AOC), 4K120Hz support, 8K60Hz support, 4K60Hz support |
Jacket Material | PVC |
Shielding Material | Aluminium-polyester foil |
Length | 9.1 m |
Plated Connector | Gold |
Features | Enhanced Audio Return Channel (eARC), HBR3 audio support, HDR 10+ support, Display Stream Compression (DSC) 1.2a, HDCP, 32 audio channels, plenum cable, bus powered, zinc alloy housing, outer diameter 4.6 mm, bandwidth of 48 Gbps, 7.1 audio channel support (HDMI) |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | HDCP 2.3 |
Dimensions & Weight (Shipping) | |
Shipping Width | 23.5 cm |
Shipping Depth | 22 cm |
Shipping Height | 3.8 cm |
Shipping Weight | 900 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
