Need to connect your Mini HDMI equipped laptop or tablet to a DVI-D digital display? This 8in Mini HDMI to DVI adapter provides the perfect solution.
Product Description | StarTech.com 8 in Mini HDMI to DVI Cable Adapter, DVI-D to HDMI (1920x1200p), 19 Pin HDMI Mini (C) Male to DVI-D Female, Digital Monitor Adapter Cable M/F, 3.9 Gbps Bandwidth, Black - Mini HDMI to DVI Adapter - adapter - HDMI / DVI - 20.32 cm | Cable | Adapter - HDMI / DVI | Technology | Double shielded | American Wire Gauge (AWG) | 30/32 | Length | 20.32 cm | Colour | Black | Connector | DVI-D - female | Connector (Second End) | 19 pin mini HDMI Type C - male | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Adapter |
Interface Supported | HDMI / DVI |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 20.32 cm |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 24+1 pin digital DVI - female |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
