ITEM | QTY | PRICE |
HP 131A Magenta Original LaserJet Ton...
4 | £359.16 |
Extend the reach of your ATX12V power supply CPU power connector by 8in. The ATXP4EXT 4 Pin P4 CPU Power Extension Cable extends the reach of your ATX12V power supply CPU power connector by 8in, making it easier to make the necessary power connection without having to ""stretch"" the CPU power connector from the power supply.
Product Description | StarTech.com 8in ATX12V 4 Pin P4 CPU Power Extension Cable - M/F - Power extension cable - 4 pin ATX12V (M) to 4 pin ATX12V (F) - 7.9 in - ATXP4EXT - power extension cable - 4 pin ATX12V to 4 pin ATX12V - 20 cm | Type | Power extension cable | Length | 20 cm | Connector | Power 4 pin ATX12V connector - male | Connector (Second End) | Power 4 pin ATX12V connector - female |
General | |
Length | 20 cm |
Connectivity | |
