SATA III (6Gbps) - PCI Express Gen 2 - PCIe x4 Slot - 2x Mini-SAS Connectors - 2x Mini-SAS to 4x-SATA Cables Included.
Product Description | StarTech.com 8 Port SATA PCIe Card, PCI Express 6Gbps SATA Expansion Card with 4 Host Controllers, SATA PCIe Controller Card, PCI-e x4 Gen 2 to SATA III Adapter Card, Drive Cables Incl. - Windows/macOS/Linux (8P6G-PCIE-SATA-CARD) - storage controller - SATA 6Gb/s / SAS 6Gb/s - PCIe 2.0 x4 | Device Type | Storage controller - plug-in card - low profile | Bus Type | PCIe 2.0 x4 | Colour | Black | Interface | SATA 6Gb/s / SAS 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Hard drive, solid state drive | Max Storage Devices Qty | 8 | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Apple MacOS X 10.10 or later, Linux 2.6.32 or later, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 8.1 / 10 / 11 | Dimensions (WxDxH) | 1.46 cm x 15 cm x 6.86 cm | Weight | 75 g | Manufacturer Warranty | 2-year warranty |
General | |
Host Bus | PCIe 2.0 x4 |
Colour | Black |
Storage Controller | |
Expansion / Connectivity | |
Interfaces | 2 x SATA 6Gb/s / SAS 6Gb/s - Mini SAS (SFF-8087) (internal) |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Cables Included | 2 x mini SAS HD to 4 x SATA HDD cable - external - 50 cm |
Features | S.M.A.R.T. support, TRIM support, 4Kn drive compatible, bootable, ATAPI support |
Compliant Standards | RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Apple MacOS X 10.10 or later, Linux 2.6.32 or later, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 8.1 / 10 / 11 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 1.46 cm |
Depth | 15 cm |
Height | 6.86 cm |
Weight | 75 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 17 cm |
Shipping Depth | 14.2 cm |
Shipping Height | 3 cm |
Shipping Weight | 81 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 20 - 80% |
