Connect fiber network devices for high-speed transfers with LSZH rated cable. The SMFIBLCSC7 7m LC to SC Single-Mode Duplex Fiber Cable features 9/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex single-mode applications.
This LC-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 9/125 (OS1) Single-Mode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Product Description | StarTech.com 7m Fiber Optic Cable - Single-Mode Duplex 9/125 - LSZH - LC/SC - OS1 - LC to SC Fiber Patch Cable (SMFIBLCSC7) - patch cable - 7 m - yellow | Type | Patch cable - OS1 | Technology | Duplex fibre optic | Features | Molded | Length | 7 m | Core / Cladding Diameter | 9 / 125 micron | Connector | 2 x SC single-mode - male | Connector (Second End) | 2 x LC single-mode - male | Colour | Yellow | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - OS1 |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
Features | Molded |
Length | 7 m |
Colour | Yellow |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
