StarTech.com 7m 40G QSFP+ Active DAC Cable
Key features
  • Delivers reliable 40Gbps connections for 40GBase-T compliant networks
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
Product codes
chevron icon
chevron icon
Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, active Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
chevron icon
Product Description StarTech.com MSA Uncoded Compatible 7m 40G QSFP+ to QSFP+ Direct Attach Breakout Cable Twinax, 40 GbE QSFP+ Copper DAC 40 Gbps Low Power Active Transceiver Module DAC, 40GE QSFP+ Cable - Lifetime Warranty (QSFP40GAC7M) - 40GBase direct attach cable - 7 m - black
Type 40GBase direct attach cable - SFF-8436
Technology Twinaxial
Features Active cable
Length 7 m
Connector QSFP+ - latched
Connector (Second End) QSFP+ - latched
Colour Black
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
