ITEM | QTY | PRICE |
D-Link DGS 3130-30PS - Switch - L3 Li...
4 | £4,409.12 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Connect your MSA compliant 10GbE SFP+ network devices with this cost-effective, active Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
Product Description | StarTech.com MSA Uncoded Compatible 7m 10G SFP+ to SFP+ Direct Attach Breakout Cable Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Active Transceiver Module DAC, 10GE Breakout Cable - Lifetime Warranty (SFP10GAC7M) - 10GBase direct attach cable - 7 m - black | Type | 10GBase direct attach cable - SFF-8431/SFF-8432 | Technology | Twinaxial | Features | Active cable | Length | 7 m | Connector | SFP+ - latched | Connector (Second End) | SFP+ - latched | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: PEX10GSFP |
General | |
Network Cable Type | 10GBase direct attach cable - SFF-8431/SFF-8432 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Impedance | 100 Ohm |
Length | 7 m |
Weight | 450 g |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | FCC, RoHS, MSA |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Compatibility Information | |
