Secure latching SATA cable designed for new system boards and SATA hard drives. The LSATA6 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
Product Description | StarTech.com Latching SATA Cable - SATA cable - 15 cm | Type | SATA cable | Interface Speed | Serial ATA 150/300/600 | Features | Latched | Length | 15 cm | Connector | 7 pin Serial ATA - receptacle | Connector (Second End) | 7 pin Serial ATA - receptacle | Colour | Red | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: 10P6G-PCIE-SATA-CARD, 25SATSAS35, 25SATSAS35HD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, CFAST2SAT25, HSB225S3R, SATSASBP425, ST521PMINT, USB2SATAIDE, USB3SSATAIDE |
General | |
Storage Cable Type | SATA cable |
American Wire Gauge (AWG) | 26 |
Length | 15 cm |
Colour | Red |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
