This fully rated 6ft USB cable features one USB A male connector and one USB B male connector, providing a high quality connection to USB 2.0 peripherals. This USB 2.0 A-B cable is constructed of only top quality materials and expertly designed for durability.
Product Description | StarTech.com 6 ft. (1.8 m) USB Printer Cable - USB 2.0 A to B - Printer Cable - Black - USB A to B (USB2HAB6) - USB cable - USB to USB Type B - 1.8 m | Type | USB cable | Features | Molded | Length | 1.8 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type B - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ICUSB2324I, IPUSB2HD3, IPUSB2VGA2, PM1115UW, PM1115UWEU, RKCOND17HD, ST12MHDLANU, ST12MHDLANUR, ST4200MINI2, SV231DPDDUA2, SV231TDVIUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA2, SV431TDVIUA, SV565UTPDUV, SV565UTPHDU, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2NA, USB3EXT6INBK |
General | |
Type | USB cable |
Features | Molded |
Length | 1.8 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, FCC |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: ICUSB2324, ICUSB2324I, IPUSB2HD3, IPUSB2VGA2, PCI420USB, PCI625USB2I, PCIUSB7, PEXUSB4DP, PM1115UW, PM1115UWEU, RKCOND17HD, ST12MHDLANU, ST12MHDLANUR, ST4200MINI, ST4200MINI2, ST4200USBM, ST4202USB, ST4202USBGB, ST7200USBM, ST7202USB, ST7202USBGB, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPUA, SV231DVIDDU, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV231USB, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV431DVIDDU, SV431TDVIUA, SV431USB, SV565USAGB, SV565UTPDUV, SV565UTPHDU, SV831DVIU, USB1000IP, USB2001EXT2, USB2001EXT2NA, USB2002EXT2, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB3EXT6INBK, USB421, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBFAA_6, USBPLATE4, USBVGADOCK2, UUSBUSBBMF |
