Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCST5 5m LSZH LC to ST Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-ST patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Product Description | StarTech.com 5m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/ST - OM2 - LC to ST Fiber Patch Cable - patch cable - 5 m - orange | Type | Patch cable - OM2 | Technology | Duplex fibre optic | Type of Fibre Optics | Multimode | Features | Molded | Length | 5 m | Core / Cladding Diameter | 50 / 125 micron | Connector | 2 x ST multi-mode - male | Connector (Second End) | 2 x LC multi-mode - male | Colour | Orange | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: MCM1110MMLC |
General | |
Network Cable Type | Patch cable - OM2 |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
Fibre Qty | 2 |
Features | Molded |
Length | 5 m |
Colour | Orange |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
