Connect your Cisco compliant 10GbE SFP+ network devices with this cost-effective, active optical cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than SFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point in-rack and across-rack network switch or server connections.
Product Description | StarTech.com Cisco SFP-10G-AOC5M Compatible 5m/16.4ft 10G SFP+ to SFP+ Active Optical Fiber, 10Gbps SFP Plus/Mini GBIC/Transceiver Module Cable, Cisco Firepower ASR1000, 10GE SFP+ Cable - Lifetime Warranty (SFP10GAOC5M) - 10GBase direct attach cable - 5 m - black | Type | 10GBase direct attach cable - SFF-8431/SFF-8432 | Technology | Fibre optic | Features | Active cable | Length | 5 m | Connector | SFP+ - latched | Connector (Second End) | SFP+ - latched | Colour | Black | OEM Manufacturer Equivalent Part Number | Cisco SFP-10G-AOC5M | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: PEX10GSFP |
General | |
Network Cable Type | 10GBase direct attach cable - SFF-8431/SFF-8432 |
Jacket Material | PVC |
Length | 5 m |
Weight | 316 g |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | FCC, RoHS, MSA |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Compatibility Information | |
