We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Enhance your system by mounting four M.2 (NGFF) SATA-based SSDs into one 3.5" drive bay. Here's an easy way to increase the speed, capacity and data security of your desktop computer or server. This four-drive M.2 SATA adapter and mounting bracket lets you add up to four M.2 solid-state drives in the same space as a single 3.5" SATA drive.
The M.2 adapter increases overall storage potential by installing four M.2 NGFF (Next Generation Form Factor) SSDs in a standard 3.5" drive bay. Utilize the full potential of your SATA III controller with an M.2 SSD, reducing data transfer bottlenecks and giving you file transfer rates of up to 6Gbps.
Create a high-performance RAID solution using four M.2 SSDs with your RAID controller to increase the volume capacity of your drive array and add redundancy to protect your data against drive failure. You can combine all four drives together to appear as one, to store larger files such as digital media and access them at faster speeds.
The adapter ensures easy and versatile use. It is designed to support a wide range of M.2 NGFF SSDs, including 2230, 2242, 2260, 2280 and 22110 drive sizes. It's also compatible with Windows, Mac, and Linux systems without having to install additional drivers or software.
Product Description | StarTech.com 4-Drive M.2 SSD (NGFF) to SATA Hard Drive Adapter for 3.5" Drive Bay - Supports 2230/2242/2260/2280/22110 M.2 NGFF SATA - 6Gbps (35S24M2NGFF) - storage controller - SATA 6Gb/s - SATA 6Gb/s | Device Type | Storage controller - internal | Bus Type | SATA 6Gb/s | Hard Drive Form Factor Compatibility | M.2 | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Solid state drive | Max Storage Devices Qty | 4 | Dimensions (WxDxH) | 10 cm x 13.9 cm x 3.4 cm | Weight | 226 g | Manufacturer Warranty | 2-year warranty |
