This 40-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
Product Description | StarTech.com 40 ft. (12.2 m) VGA to VGA Cable - HD15 Male to HD15 Male - Triple-Coaxial - High Quality - VGA Monitor Cable (MXT101MMHQ40) - VGA cable - 12.2 m | Type | VGA cable | Technology | Triple shielded twisted pair coaxial | Features | Molded, ferrite bead | Length | 12.2 m | Connector | HD-15 (VGA) - male | Connector (Second End) | HD-15 (VGA) - male | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: CDP2VGA, CDP2VGAFC, DVI2VGAE, DVIVGAMF, DVIVGAMFBK, HD2VGAE2, HD2VGAMICRO |
General | |
Type | VGA cable |
Shielding Material | Aluminum mylar foil with braid |
American Wire Gauge (AWG) | 28 |
Plated Connector | Nickel |
Length | 12.2 m |
Colour | Black |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - male |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
