This 11-inch iPad Pro Privacy Screen smoothly transitions from a clear view to an obscured screen beyond the intended viewing angle, significantly enhancing visual privacy in office or public environments. The anti-glare matte finish helps to reduce reflections in glare-prone environments and provides additional screen protection with a scratch and fingerprint-resistant coating.
Product Description | StarTech.com - screen protector for tablet - for portrait/landscape, touch-enabled, +/-30° view, blocks up to 51% blue light, anti-glare | Product Type | Screen protector - with privacy filter - 4-way | Intended For | Tablet | Screen Size Compatibility | 11" | Protection | Scratch-resistant, anti-glare, blue light reduction, fingerprint-resistant | Package Content | Screen protector, cleaning wipes, squeegee, dust remover, 2 guide stickers, wiping cloth | Product Material | Plastic | Dimensions (WxDxH) | 17 cm 24.5 cm | Thickness | 0.4 mm | Weight | 43 g | Colour | Black | Manufacturer Warranty | 2-year warranty | Designed For | Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation) |
General | |
Product Type | Screen protector - with privacy filter |
Privacy Protection | 4-way |
Width | 17 cm |
Height | 24.5 cm |
Weight | 43 g |
Colour | Black |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 39 cm |
Shipping Depth | 0.6 cm |
Shipping Height | 24.5 cm |
Shipping Weight | 140 g |
Compatibility Information | |
