Add 4 Gigabit Power over Ethernet ports to a PCI Express-enabled computer. The ST4000PEXPSE 4-Port PoE NIC lets you add four Gigabit Power over Ethernet ports through a single PCI Express slot. Each port can provide up to 25.5W of power, combining network data and power over a single Ethernet cable for reduced cable clutter and added convenience for remote PoE devices.
The PCI express PoE card supports the IEEE 802.3at (Type 1 and 2) standard for Power Sourcing Equipment (PSE), and can deliver up to 48V DC power to compliant Powered Devices (PD). This eliminates the need for a separate power source and data connection for PoE devices such as IP cameras, IP phones or wireless access points.
Suitable for any standard profile PCIe-enabled client, server or workstation, the PoE network card supports features such as Jumbo Frames (up to 9KB), VLAN tagging and Wake on LAN (WoL).
Product Description | StarTech.com 4 Port Gigabit PoE (Power over Ethernet) Card - PCIe Network Card - PoE / PoE+ Up to 25W Per Port - PCIe NIC - Gigabit Ethernet Card (ST4000PEXPSE) - network adapter - PCIe x4 - Gigabit Ethernet x 4 | Device Type | Network adapter | Form Factor | Plug-in card | Interface (Bus) Type | PCI Express x4 | Ports | Gigabit Ethernet x 4 | Dimensions (WxDxH) | 12 cm x 24 cm x 1.8 cm | Cabling Type | Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T | Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE | Data Transfer Rate | 1 Gbps | Processor | Realtek Semiconductor RTL8111E | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Status Indicators | PoE, link/activity |
Features | Full duplex capability, PoE, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, 48KB packet buffer |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T (PoE) - RJ-45 (external) , 1 - 4 PIN internal power (internal) , 1 - 15 pin Serial ATA power (internal) |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 |
Dimensions & Weight | |
Width | 12 cm |
Depth | 24 cm |
Height | 1.8 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
