Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
Product Description | StarTech.com HPE J9283B Compatible 3m 10G SFP+ to SFP+ DAC Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Passive Mini GBIC/Transceiver Module DAC Firepower 1040, 10 Gbps SFP+ Cable - Lifetime Warranty (J9283BST) - 10GBase direct attach cable - 3 m - black | Type | 10GBase direct attach cable - SFF-8431/SFF-8432 | Technology | Twinaxial | Features | Passive cable | Length | 3 m | Connector | SFP+ - male - latched | Connector (Second End) | SFP+ - male - latched | Colour | Black | OEM Manufacturer Equivalent Part Number | HP J9283B | Manufacturer Warranty | 2-year warranty |
General | |
Network Cable Type | 10GBase direct attach cable - SFF-8431/SFF-8432 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 30 |
Impedance | 100 Ohm |
Length | 3 m |
Weight | 130 g |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | FCC, RoHS, MSA |
Manufacturer Warranty | |
Service & Support | 2-year warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
