Bridge the gap in your workspace with StarTech.com's new cross-wired patch cables. Constructed with only top quality components, the colored hoods help keep things in your department organized. Strain relief minimizes the damage to the ends of the plugs by preventing the cable from being bent at sharp angles.
Product Description | StarTech.com Molded Cat5e Crossover UTP Patch Cable - crossover cable - 10.7 m - blue | Type | Crossover cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568A | Wires per Cable | 8 wires | Features | Molded | Length | 10.7 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Blue | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Crossover cable - CAT 5e |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Features | Molded |
Length | 10.7 m |
Colour | Blue |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
