Connect your HDMI devices, up to 30m away with no signal loss. This active HDMI cable offers a connection distance of up to 100 feet (30 meters) between your HDMI enabled devices. It meets CL2 rating safety requirements, so it's ideal for in-wall cable runs in your home and office installations.
The cable features built-in amplifier circuitry which actively boosts your HDMI signal, with no external power required, which is the perfect solution for longer transmissions without any signal loss.
The HDMI cable is CL2-rated for in-wall installations making them perfect for office or residential cable runs. You can set up your home theater, gaming or audio-video equipment with the cables hidden away safely inside the walls and place your devices as needed throughout your work or living space.
This high-quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high-definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
Product Description | StarTech.com 30m 100 ft High Speed HDMI Cable M/M - Active - 26AWG - CL2 rated In-wall Installation - Ultra HD 4k x 2k - Active HDMI Cable (HDMM30MA) - HDMI cable - 30 m | Cable | HDMI cable | Technology | Double shielded | American Wire Gauge (AWG) | 26 | Length | 30 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Features | CL2 rated jacket, in wall mounting, active cable (signal regeneration) | Manufacturer Warranty | 2-year warranty |
General | |
Cable Type | HDMI cable |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 30 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
