Allows an HDMI connection to be mounted on a secure and easily accessible panel. The HDMIPNLFM3 3ft Standard HDMI Cable for Panel Mount features an HDMI male connector on one end, and an HDMI panel mount (female) molded connector on the other, providing a well-secured, easy to access HDMI connection on any machine port or faceplate.
Product Description | StarTech.com 3ft HDMI Female to Male Adapter, 4K High Speed Panel Mount HDMI Cable, 4K 30Hz UHD HDMI, 10.2 Gbps Bandwdith, 4K HDMI 1.4 Video, HDCP 1.4, HDMI Female to HDMI Male Cable - HDMI Panel Mount Connector - HDMI cable - 91 cm | Cable | HDMI cable | American Wire Gauge (AWG) | 28 | Length | 91 cm | Colour | Black | Connector | HDMI - female | Connector (Second End) | HDMI - male | Features | Molded | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB |
General | |
Cable Type | HDMI cable molded |
Jacket Material | PVC |
Length | 91 cm |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - female |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
