Eliminate excess cable clutter with a short 3ft Mini DisplayPort to DVI active adapter. The MDP2DVIMM3WS 3ft active Mini DisplayPort to DVI adapter cable lets you directly connect your Mini DP video source (Laptop, Macbook, Ultrabook etc.) directly to a nearby DVI monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable. The converter features a stylish white design, that is well-suited for connecting Mac computers.
For guaranteed compatibility with virtually any Mini DisplayPort output the active Mini DP to DVI adapter supports multimode (DP++) as well as single-mode DisplayPort signals. Unlike passive adapters, this ensures the MDP2DVIMM3WS can be used with graphics cards that are not capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 2560x1600.
Product Description | StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 3ft (0.9m) Active mDP to DVI M/M Cable - 1920x1200 - White (MDP2DVIMM3WS) - DisplayPort cable - 90 cm | Type | DisplayPort cable | Features | Active cable (signal regeneration) | Length | 90 cm | Connector | Mini DisplayPort - male | Connector (Second End) | DVI-D - male | Compliant Standards | FCC, RoHS | Colour | White | Manufacturer Warranty | 3-year warranty |
General | |
Length | 90 cm |
Colour | White |
Connectivity | |
Connector (Second End) | 24+1 pin digital DVI - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
