Connect power eSATA devices to the eSATA and USB ports on your computer. This eSATA and USB A Male to Power eSATA Cable provides a 3 ft connection between an external drive enclosure equipped with a power eSATA port and the eSATA and USB port on a PC/notebook, providing both power (through USB) and data (through SATA) using a single cable.
The 3 ft eSATA and USB A Male to Power eSATA Male cable is expertly designed and constructed of only top quality materials.
Product Description | StarTech.com eSATA and USB A to Power eSATA Cable - Power Over eSATA cable - 91 cm | Type | Power Over eSATA cable | Length | 91 cm | Connectors | 11 pin USB/eSATA - male | Connectors (Second End) | 7 pin external Serial ATA - male , 4 pin USB Type A - male | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: S251SMU33EP |
General | |
Storage Cable Type | Power Over eSATA cable |
Length | 91 cm |
Connectivity | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
