ITEM | QTY | PRICE |
Apple Magic Keyboard with Numeric Key...
2 | £248.90 |
Lenovo ThinkVision P27h-20 27" 2...
3 | £1,212.12 |
BT 7660 Twin
4 | £199.96 |
Connect USB 2.0 peripherals to your computer, for installation in narrow spaces. The USB2HAB2RA3 3ft USB A-to-B cable features a right angle USB ''A'' male connector and a right angle USB ''B'' male connector, for high quality connections to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives, even in hard to reach areas and narrow spaces.
The right-angled USB connectors position the cable nearly flush against a wall or other surface, and eliminate the space typically required to accommodate a ''straight'' connection from the cable into the USB port or peripheral device.
Product Description | StarTech.com 3 ft / 91cm A Right Angle to B Right Angle USB Cable - 0.91m Right Angle USB 2.0 - 1x USB A 1x USB B - Black (USB2HAB2RA3) - USB cable - USB to USB Type B - 91 cm | Type | USB cable | Technology | Shielded twisted pair (STP) | Features | 90° connector, molded | Length | 91 cm | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type B - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ICUSB23208FD, ICUSB23216FD, ICUSB232D |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 24/28 |
Length | 91 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
