Extend the connection distance between your HDMI-enabled devices by 2 meters. The HDEXT2M HDMI extension cable (2m) features an HDMI 19-pin (male) connector on one end and an HDMI 19-pin (female) connector on the other, providing an extra 2-meter connection distance between your HDMI-enabled devices.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI extension cables are expertly designed and constructed of only top quality materials to ensure high quality, high-definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
Product Description | StarTech.com 2m (6ft) HDMI Extension Cable, Ultra HD HDMI Male to Female Cable, 4K HDMI Cable Extender, 4K 30Hz UHD HDMI Cable with Ethernet M/F, High Speed HDMI 1.4 Cable, 10.2Gbps - HDMI Cord Extender - HDMI extension cable - 2 m | Cable | HDMI extension cable | Technology | Shielded | American Wire Gauge (AWG) | 28 | Length | 2 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | HDMI - female | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB |
General | |
Cable Type | HDMI extension cable |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 2 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - female |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
