Charge or Sync your wall/stand-mounted iPhone, iPod or iPad with the cable out of the way. The USB2ADC2MD Dock Connector to USB cable for iPhone, iPod and iPad (2m) features a down-angled Apple (30-pin) Dock Connector, which is ideal for wall-mounted or stand-mounted applications because it positions the cable behind your iOS-enabled mobile digital device for a neater installation that keeps the cable out of the way.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, this uniquely constructed Dock Connector to USB cable features a stepped Apple Dock Connector, designed by StarTech.com, which unlike a regular connector plugs into your iPhone, iPod or iPad, even when inside a protective case while avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description | StarTech.com 2m Down Angle Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 2 m | Cable | Charging / data cable | Technology | Shielded | American Wire Gauge (AWG) | 24 | Length | 2 m | Colour | White | Connector | USB - male | Connector (Second End) | Apple Dock - male | Features | Angled connector | Manufacturer Warranty | Limited lifetime warranty | Designed For | Apple iPod (4G, 5G); iPod classic; iPod mini |
General | |
Cable Type | Charging / data cable angled connector |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 2 m |
Plated Connector | Nickel |
Features | Sync and charge |
Colour | White |
Connectivity | |
Connector | 4 pin USB Type A - male |
Connector (Second End) | Apple Dock connector - male |
Miscellaneous | |
Compliant Standards | RoHS, MFI |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
Designed For | Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini |
