Add RS-232 serial communication support to USB-A enabled Data Terminal Equipment (DTE - e.g., desktop or laptop), using this 2ft (61cm) straight through 2-Port USB to Serial Adapter Cable.
Product Description | StarTech.com 2ft (60cm) 2-Port USB to Serial Adapter Cable, Interchangeable DB9 Screws/Nuts, COM Retention, USB-A to DB9 RS232, FTDI, Level-4 ESD Protection, Windows/macOS/ChromeOS/Linux - Rugged TPE Construction (2P1FFC-USB-SERIAL) - USB / serial cable - USB to DB-9 - 60 cm | Type | USB / serial cable | Features | EMI/RFI protection, electrostatic discharge (ESD) protection, FTDI controller, LED status indicator, TPE connector housing, bus powered | Length | 60 cm | Connector | 4 pin USB Type A - male | Connector (Second End) | 2 x 9 pin D-Sub (DB-9) - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Shielding Material | Copper |
Plated Connector | Gold |
Length | 60 cm |
Colour | Black |
Weight | 110 g |
Connectivity | |
Miscellaneous | |
Included Accessories | Mounting bracket |
Compliant Standards | USB / USB 2.0, RS-232 |
Dimensions & Weight (Shipping) | |
Shipping Width | 22.5 cm |
Shipping Depth | 15.5 cm |
Shipping Height | 5.5 cm |
Shipping Weight | 160 g |
Service & Support | 2-year warranty |
