Add an un-managed, 20-slot media converter chassis to your rack or cabinet. The ETCHS2U 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Media Converters lets you add an un-managed, 20-slot media converter chassis to your rack or cabinet to provide central power and cooling.
The media converter rack includes a single 200W power supply to centrally power all 20 slots, with an additional slot to add a redundant power supply for maximum up-time. It also includes two cooling fans (one per side) to help extend the life of your media converters.
A perfect accessory to the StarTech.com ET series 2 converters, the 2U chassis is designed so that all critical components (Power, Fans and Media Converter Cards) are hot swappable to avoid network disruption.
Product Description | StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converters (ETCHS2U) - modular expansion base | Device Type | Modular expansion base | Form Factor | Rack-mountable - 2U | Localisation | North America, United Kingdom, Europe | Power | AC 120/230 V (50/60 Hz) | Power Redundancy | Optional | Dimensions (WxDxH) | 43.8 cm x 30.3 cm x 8.8 cm | Weight | 5 kg | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ET1000S40LC2, ET90110SC2, ET90110SM302, ET90110ST2, ET90110WDM2, ET91000LC2, ET91000LCOAM, ET91000SC2, ET91000SFP2, ET91000SFP2C, ET91000SM402 |
General | |
Height (Rack Units) | 2U |
Installed Modules Qty (Max) | 0 (20) |
Width | 43.8 cm |
Depth | 30.3 cm |
Height | 8.8 cm |
Weight | 5 kg |
Enclosure Colour | Black |
Networking | |
Form Factor | Rack-mountable |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Expansion Slots | 20 (total) / 20 (free) x expansion slot |
Miscellaneous | |
MTBF | 65,000 hours |
Compliant Standards | UL, FCC, RoHS |
Power | |
Power Device | Internal power supply - hot-plug |
Installed Qty | 1 |
Max Supported Qty | 2 |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 60 Watt |
Power Provided | 200 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 5 - 90% (non-condensing) |
Compatibility Information | |
