ITEM | QTY | PRICE |
Doro 6880 4G Red 2.8in
4 | £359.92 |
Add two external USB 2.0 ports to your small form factor PC. The USBPLATELP 2 Port Low Profile USB Bracket converts the USB pins on a USB 2.0 motherboard header to 2 standard USB A ports.
An ideal solution for small form factor computer cases, the slot plate can be mounted on the rear panel of your low profile or thin client computer case - adding two USB female ports for simple connection to USB peripheral devices.
Product Description | StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter - 2 Port USB Bracket - USB 2.0 A Female (USBPLATELP) - USB panel - USB to 5 pin in-line | Type | USB panel | Connector | 2 x 4 pin USB Type A - female | Connector (Second End) | 2 x 5 pin in-line - female | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | USB panel |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
