Turn a 2.5" SATA Hard Drive or Solid State Drive into a UASP supported USB 3.0 External Hard Drive. The S2510BMU33 USB 3.0 Hard Drive Enclosure with UASP lets you connect a 2.5in SATA III hard drive (HDD) or solid state drive (SSD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 2.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 1TB) this HDD enclosure is compatible with virtually any 2.5in SATA hard drive, and greatly increase the storage/backup capabilities of your computer.
The USB 3.0/SATA III enclosure requires no external power adapter and features high quality aluminum construction, ensuring both portability and durability when carried as a laptop accessory.
Product Description | StarTech.com 2.5" Hard Drive Enclosure - Supports UASP - SATA 6Gbps - USB 3.0 External Hard Drive Enclosure - SSD/HDD Enclosure (S2510BMU33) - storage enclosure - SATA 6Gb/s - USB 3.0 | Device Type | Storage enclosure - external | Bus Type | USB 3.0 | Colour | Black | Expansion Bays | 1 x internal - 2.5" | Hard Drive Form Factor Compatibility | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 5 GBps | Supported Devices | Hard drive | Max Storage Devices Qty | 1 | Product Material | Plastic, aluminium | Power Source | USB bus | System Requirements | Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits) | Dimensions (WxDxH) | 7.7 cm x 12 cm x 1.55 cm | Weight | 97.7 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: HB30C1A1CPD, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, USBDUP15, USBDUPE115, USBDUPE17 |
General | |
Hard Drive Maximum Height | 9.5 mm |
Host Bus | USB 3.0 |
Colour | Black |
Storage Controller | |
Expansion / Connectivity | |
Interfaces | 1 x SATA 6Gb/s - SATA combo |
Connections | 1 x USB 3.0 - 10 pin Micro-USB Type B |
Miscellaneous | |
Cables Included | 1 x USB cable - external - 45.7 cm |
Features | USB powered, LED indicator |
Mounting Kit | Included |
Compliant Standards | RoHS |
Power | |
Software / System Requirements | |
OS Required | Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 7.7 cm |
Depth | 12 cm |
Height | 1.55 cm |
Weight | 97.7 g |
Environmental Parameters | |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
