Charge or sync your Micro USB devices, with the cable kept out of the way. The USBAUB1MD 1m USB to Down Angle Micro USB Cable provides a high quality connection between your Micro USB 2.0 mobile devices (smartphones, digital cameras, Tablet PC devices, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The down-angled Micro USB connector allows you to access your mobile Micro USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a 1m USB to Up Angle Micro USB Cable (USBAUB1MU), which provides the same convenience as this down-angled cable, but allows you to connect to your Micro USB device from the opposite direction.
Product Description | StarTech.com 1m Micro USB Cable - A to Down Angle Micro B - USB cable - Micro-USB Type B to USB - 1 m | Type | USB cable | Technology | Double shielded | Features | 90° connector, molded, strain relief | Length | 1 m | Connector | 5 pin Micro-USB Type B - male | Connector (Second End) | 4 pin USB Type A - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 28 |
Plated Connector | Nickel |
Length | 1 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
