Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM1M 1m DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 1m DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
Product Description | StarTech.com 1m DVID Dual Link Cable M/M - DVI cable - 1 m | Type | DVI cable - dual link | Technology | Shielded | Features | Thumbscrews | Length | 1 m | Connector | DVI-D - male | Connector (Second End) | DVI-D - male | Compliant Standards | RoHS | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | DVI cable |
Shielding Material | Aluminum mylar foil with braid |
American Wire Gauge (AWG) | 28 |
TMDS Links | Dual link |
Plated Connector | Nickel |
Length | 1 m |
Colour | Black |
Connectivity | |
Connector | 24+1 pin digital DVI - male |
Connector (Second End) | 24+1 pin digital DVI - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
