Charge or sync micro USB mobile devices from a standard USB port on your desktop or mobile computer. The UUSBHAUB1 1-foot USB A to Micro USB cable features one USB 'A' male connector, and one 'Micro-B' male connector, providing a high quality connection to USB 2.0 mobile devices (such as BlackBerry or Android-based cellular phones, digital cameras, Tablet PC devices and GPS systems) that use a Micro USB connector to a USB capable computer for everyday tasks such as data synchronization and file transfers.
Product Description | StarTech.com 1 ft. (0.3 m) USB to Micro USB Cable - USB 2.0 A to Micro B - Black - Micro USB Cable (UUSBHAUB1) - USB cable - USB to Micro-USB Type B - 30.5 cm | Type | USB cable | Length | 30.5 cm | Connector | 4 pin USB Type A - male | Connector (Second End) | 5 pin Micro-USB Type B - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: BNDDKTCHVPRS, CDP2HDUACP2, CMDPHD2HD, DK30C2HAGPD, DKT30CHCPD, DKT30CHD, DKT30CHPD3, DKT30CHPDW, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DKT30CHVW, DKT31CMDPHPD, KITBXAVHDPNA, KITBZPOWNA, MOD4POWEREU, MOD4POWERNA, MOD4POWERUK, PIB2M21, ST7C51224, ST7C51224EU, TB3DKM2DPL, TB3DKM2HD, TB3DKM2HDL |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 28 |
Length | 30.5 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: BNDDKTCHVPRS, CDP2HDUACP, CDP2HDUACP2, CDP2HDUACPW, CDP2VGAUACP, CDP2VGAUCP, CMDPHD2HD, DK30C2HAGPD, DKT30CHCPD, DKT30CHD, DKT30CHPD, DKT30CHPD3, DKT30CHPDW, DKT30CHV, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DKT30CHVW, DKT31CMDPHPD, DPMDPHD2HD, DVI2VGAMM10, DVI2VGAMM3, DVI2VGAMM6, HD2VGAMM10, HD2VGAMM3, KITBXAVHDPNA, KITBZPOWNA, MOD4POWEREU, MOD4POWERNA, MOD4POWERUK, MST30C2DPPD, PIB2M21, PIB2MS1, PIB2S31, ST4CU424, ST4CU424EU, ST4CU424UK, ST73007UA, ST7C51224, ST7C51224EU, ST8CU824, SV231USBLC, TB3DKM2DPL, TB3DKM2HD, TB3DKM2HDL, USB2PCARBK, USB2PCARBKS, USB3VDOCKD, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBPLATE4, USBUB2PCARB |
