This eSATA plate (low profile) adds external data support to any existing Serial ATA (SATA) controller, allowing you to connect external SATA (eSATA) storage to a computer. With support for data transfer rates of up to 300MBps, this external SATA plate allows you to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections. Connecting eSATA storage couldn't be simpler. Just install the plate into an open I/O low profile slot on your computer and connect the cables to the Serial ATA connectors on your motherboard or controller card. The slim SATA data cable connecting the motherboard or controller card SATA connection to ESATAPLT1LP is designed to take up minimal space inside the computer case, providing less clutter for increased airflow inside your case.
Product Description | StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter - eSATA Slot Bracket - Low Profile SATA to eSATA Bracket (ESATAPLT1LP) - SATA internal to external panel - 30 cm | Type | SATA internal to external panel | Interface Speed | Serial ATA 150/300/600 | Features | Low profile | Length | 30 cm | Connector | 7 pin Serial ATA - female | Connector (Second End) | 7 pin external Serial ATA - male | Colour | Red | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: S251SMU33EP, S351BMU33ET, S351BMU33ETG, SDOCKU313E, SDOCKU33EF |
General | |
Storage Cable Type | SATA internal to external panel |
Length | 30 cm |
Colour | Red |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
