This 9-pin Serial to 10-pin Header Slot Plate adapter features one DB9 male connector and one IDC10 connector. The adapter is constructed of high quality components and expertly designed to ensure durability and reliability.
Please refer to the Technical Specifications to ensure your motherboard is compatible with this product.
Product Description | StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate - motherboard Serial Port Adapter (PLATE9M16) - serial panel - DB-9 to 10 PIN IDC - 41 cm | Type | Serial panel | Length | 41 cm | Connector | 9 pin D-Sub (DB-9) - male | Connector (Second End) | 10 PIN IDC - female | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty |
General | |
Length | 41 cm |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
