Reliably extend the distance of a USB 2.0 device an additional 15ft. This 15ft USB 2.0 Active Extension Cable offers one USB A male connector and one USB A female connector, providing an active, bus-powered extension of a USB 2.0 device connection by up to 15ft (4.5m).
The extension cable (USB Extender) supports high speed USB 2.0 transfer rates of up to 480Mbps.
Product Description | StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 15 ft - active - USB2FAAEXT15 - USB extension cable - USB to USB - 4.6 m | Type | USB extension cable | Features | Active cable (signal regeneration) | Length | 4.6 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type A - female | Compliant Standards | USB / USB 2.0 | Manufacturer Warranty | 2-year warranty | Designed For | P/N: 35FCREADBK3, ICUSB1284, ICUSB128410, ICUSB1284D25, ICUSB232, ICUSB2321FIS, ICUSB2321X, ICUSB2322F, ICUSB2322X, ICUSB2324X, ICUSB2328, ICUSB232SM3, MSDREADU2OTG, USBPS2PC, UUSBOTG |
General | |
Length | 4.6 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, Plug and Play, FCC |
Dimensions & Weight (Shipping) | |
Service & Support | 2-year warranty |
Compatibility Information | |
