This 15ft clear USB 2.0 A-B cable offers one USB A connector and one USB B connector, and features an attractive transparent jacket.
Product Description | StarTech.com 15 ft Transparent USB 2.0 Cable - A to B - USB cable - USB (M) to USB Type B (M) - USB 2.0 - 15 ft - molded - transparent - USB2HAB15T - USB cable - USB to USB Type B - 4.6 m | Type | USB cable | Technology | Shielded foiled twisted pair (SFTP) | Features | Molded | Length | 4.6 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type B - male | Compliant Standards | USB / USB 2.0 | Colour | Transparent | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ICUSB2328, PCI420USB, PCI625USB2I, PCIUSB7, PEXUSB4DP, SV231DPU, SV231DPUA, SV231HDMIUA, USB2002EXT2 |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 24/28 |
Features | Molded |
Length | 4.6 m |
Connectivity | |
Miscellaneous | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
