Power an LP4 Molex device from a SATA Power connection on your computer power supply. The LP4SATAFM12 SATA to LP4 Power Cable Adapter enables you to power 4-pin Molex devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) from a SATA power connector on your computer power supply. Offering 12 inches in cable length, the cable allows you to position your devices as needed within the system case.
Product Description | StarTech.com 12in SATA to LP4 Power Cable Adapter F/M - SATA to LP4 Power Adapter - SATA Female to LP4 Male Power Cable - 12 inch (LP4SATAFM12) - power adapter - 4 PIN internal power to SATA power - 30.48 cm | Type | Power adapter | Length | 30.48 cm | Connector | 4 PIN internal power - female | Connector (Second End) | 15 pin Serial ATA power - male | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: SATSASBP425 |
General | |
American Wire Gauge (AWG) | 18 |
Length | 30.48 cm |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
