Extend a SATA Power Connection by up to 12in. The SATAPOWEXT12 SATA Power Extension Cable (15-pin, 12-inch) enables you to extend the reach between internal SATA power and drive connections by up to 12 inches.
The extension cable helps to simplify drive installation by overcoming typical connection limitations and reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
Product Description | StarTech.com 12in 15 pin SATA Power Extension Cable - SATA Power Male to Female Extender - 12 Inch SATA Power Extension Cord - power extension cable - SATA power to SATA power - 30.5 cm | Type | Power extension cable | Length | 30.5 cm | Connector | 15 pin Serial ATA power - male | Connector (Second End) | 15 pin Serial ATA power - female | Manufacturer Warranty | 1-year warranty | Designed For | P/N: PYO2SATA, PYO4SATA, SATAPOWADAP |
General | |
Length | 30.5 cm |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | 1-year warranty |
Compatibility Information | |
