Add RS-232 DCE serial communications support to a desktop or laptop computer and resolve DCE/DTE conflicts directly without the need for additional cross-wired serial cables or adapters.
Product Description | StarTech.com 10ft (3m) USB to Null Modem Serial Adapter Cable, Interchangeable DB9 Screws/Nuts, COM Retention, USB-A to RS232, FTDI, Level-4 ESD Protection, Windows/macOS/ChromeOS/Linux - Rugged TPE Construction (1P10FFCN-USB-SERIAL) - USB / serial cable - USB to DB-9 - 3 m | Type | USB / serial cable | Features | EMI/RFI protection, electrostatic discharge (ESD) protection, FTDI controller, LED status indicator, TPE connector housing, bus powered | Length | 3 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 9 pin D-Sub (DB-9) - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Shielding Material | Copper |
Plated Connector | Gold |
Length | 3 m |
Colour | Black |
Weight | 120 g |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, RS-232 |
Dimensions & Weight (Shipping) | |
Shipping Width | 22 cm |
Shipping Depth | 0.1 cm |
Shipping Height | 20 cm |
Shipping Weight | 130 g |
Service & Support | 2-year warranty |
