ITEM | QTY | PRICE |
Logitech Signature MK650 Combo for Bu...
4 | £232.72 |
BT Converse 2100 White Corded Phone
4 | £131.92 |
Ezviz Full HD Outdoor Floodlight Secu...
4 | £239.92 |
This 10 ft Cross Wired Serial/Null Modem Cable features one DB9 female and one DB9 male connector, allowing you to connect a serial printer to a 9 pin serial port, or transfer files from PC to PC via serial connection. This serial/null modem cable is designed to provide a reliable, long-lasting connection.
Product Description | StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M - Null modem cable - DB-9 (M) to DB-9 (F) - 10 ft - SCNM9FM - null modem cable - DB-9 to DB-9 - 3 m | Type | Null modem cable | Length | 3 m | Connector | 9 pin D-Sub (DB-9) - male | Connector (Second End) | 9 pin D-Sub (DB-9) - female | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: EC1S232U2, ICUSB23208FD, ICUSB23216FD, ICUSB2321FIS, ICUSB2322F, ICUSB2322I, ICUSB232IS, ICUSB232PROC, ICUSB232SM3, NETRS232, NETRS2321P, NETRS2322P, NETRS232485W, PCI2S232485I, PCI2S4851050, PCI4S954PW, PEX1S553LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX4S553, PEX4S553B |
General | |
Length | 3 m |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: 10PKPCI1S550, EC1S232U2, EC1S952, EC2S952, IC485S, ICUSB232, ICUSB23208FD, ICUSB23216FD, ICUSB2321FIS, ICUSB2321X, ICUSB2322F, ICUSB2322I, ICUSB2322X, ICUSB2324X, ICUSB2328, ICUSB232DB25, ICUSB232IS, ICUSB232PROC, ICUSB232SM3, ICUSB422IS, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W, PCI1S550, PCI2S1P, PCI2S232485I, PCI2S4851050, PCI2S550, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP |
