ITEM | QTY | PRICE |
TP LINK Kasa KE100KIT Smart Valve + K...
4 | £319.96 |
Convert and extend a 10/100 Mbps Ethernet connection up to 18.6 miles/30km over Single Mode SC fiber. The ET90110SM302 10/100 Mbps Single Mode Fiber Media Converter SC (30 km) lets you extend a Fast Ethernet network (10/100) over single mode fiber, at distances up to 30 km (18.6 miles).
A cost-effective solution for connecting a 10/100 Mbps Ethernet (10/100Base-T) network to remote network segments over a 100Base-FX fiber backbone, the media converter is designed to offer a durable and convenient Ethernet to fiber solution, with an all-steel chassis, and simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Product Description | StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC - 18.6 miles/30km over Single Mode SC Fiber (ET90110SM302) - fibre media converter - 10Mb LAN, 100Mb LAN | Device Type | Fibre media converter - RJ-45 / SC single-mode | Form Factor | External | Localisation | North America, United Kingdom, Europe | Cabling Type | 100Base-FX | Data Transfer Rate | 100 Mbps | Optical Wave Length | 1310 nm | Data Link Protocol | 10Mb LAN, 100Mb LAN | Max Transfer Distance | 30 km | Power | AC 120/230 V | Dimensions (WxDxH) | 9.5 cm x 16 cm x 2 cm | Weight | 0.6 kg | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA |
General | |
Device Type | Fibre media converter |
Colour | Black |
Networking | |
Connectivity Technology | Wired |
Features | Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged |
Expansion / Connectivity | |
Interfaces | 1 x network - RJ-45 female , 1 x Ethernet 100Base-FX - SC single-mode female x 2 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Dimensions & Weight | |
Width | 9.5 cm |
Depth | 16 cm |
Height | 2 cm |
Weight | 0.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
